Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › HOOVER HVBF6182XFHK 34002039 off
- This topic has 7 replies, 5 voices, and was last updated 8 years, 1 month ago by
alro.
March 2, 2018 at 9:51 pm #93447
alro
ParticipantHi gents need help fridge freezer does nothing no light in fridge( dead machine) have 240v at compressor terminal and 240v going into PCB nothing works does anyone have tech info on this machine( wiring diagram) as its a live brown wire going up into the body of machine but there is no brown wire feeding live onto pcb its black so i do not know were the brown wire goes to in the machine cheers alro
March 2, 2018 at 10:51 pm #454328electrofix
ModeratorRe: HOOVER HVBF6182XFHK 34002039 off
have no access to tech on this personally but looked up the board. if it is the correct one it seems to have a 4 pole connector at one end and 2 of these connections are marked L & N
as long as the board is getting live and neutral then it should work if its ok
March 3, 2018 at 8:07 am #454329kaibart
Not much tech info for this fridge freezer is it in a house where the temp is between 5c and 15c otherwise it wount work
March 3, 2018 at 2:35 pm #454330alro
ParticipantRe: HOOVER HVBF6182XFHK 34002039 off
Kaibert home fine oaps house warm, the problem i have its a brown wire at compressor terminal block feeding into body of machine( live ) but changes to a black wire (live) into pcb no brown wire going to pcb atall as the neons (light in fridge)dont work as does the hole machine is dead cheers alro could it be the temp setting in the fridge (pcb) or the main pcb its the light in fridge not working makes me think its the main pcb as the light would work if set on 0 in fridge ?? love to have tech on this one
March 3, 2018 at 3:50 pm #454331bazza500
Brown wire seems to go from plug to CN101 on main board. If you give me an email address I’ll email the wiring diagram.
March 4, 2018 at 12:10 pm #454332alro
bazza sent my email address to your box cheers alro
March 4, 2018 at 4:00 pm #454333eastlmark
sure not a “hidden” on off switch anywhere? Wouldn’t be the first time I have been called out to a dead fridge only to find it turned off at an on off switch the owners swear they never knew about despite owning it for years.
March 4, 2018 at 6:22 pm #454334alro
thanks for wiring dia bazza that brown live changes to black at the pcb and i do have live on that wire so it must be the pcb u/s cheers alro
