Hi, I am having a problem with the above washer dryer, mostly when on a dry cycle. The problem is that when the drum changes direction there is a loud noise and the drum revolves very fast for a while before retuning to normal. Also, you can see a spark underneath as this happens.
The machine has been moved a lot recently as we have had a new kitchen fitted. Could something have loosened? Or am I in need of new parts? Any advice you could offer would be most appreciated.
Many thanks in advance, Rich.
