Hoover HW160M UK (403003868) Washer/Dryer Dryer Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HW160M UK (403003868) Washer/Dryer Dryer Problem
  • #91223
    jontymox
    Good afternoon,
    Wondering if someone can advise on a problem with the above machine?
    My customer reported a problem setting programmes, and laundry coming out warm at the end of a drying cycle.
    I confirmed that the main mechanical selector/programmer is worn internally, hence the control doesn’t align too well with the selected programme, and requires a new unit.
    However, I’m not sure about the laundry being warm after a drying cycle of around one hour.
    Should I suspect a condenser, or blockage issue and if there is a common fault which would cause this?
    Kind regards,
    jonty
    #447466
    Re: Hoover HW160M UK (403003868) Washer/Dryer Dryer Problem
    it will never be cold there is no way to vent all the hot air,
