Was called out to this machine today, not heating and taking a long time to complete cycles. Heater continuity & insulation both fine, motor a bit low insulation (70Mohms) but brushes okay everything else working fine. Two stats, left no resistance (closed circuit), right readings seemed about right. Heater wires continuity fine. There is actually some power supplied to the heater, but less than 1V – enough to light the neon but not heat the water.
Can this be anything else other than the timer? Tempted to BER it with motor insulation being lowish anyway. Customer very difficult (went to machine in December for blocked filter, she’s still insisting this is the same fault). Thanks in advance :).
