Hoover HW6316M NDA
  • #36881
    Turbo
    This washer dryer has no drum action, motor ok so suspect one of the two modules. Is it likely to be the large control module at the top of machine or the small module near the motor? Would normally go for the small module but I did hear a relay clicking noise coming from the large control module when I tried a wash program 😕
    Any help would be great.
    Thanks, Graham.
    #252655
    simonb
    Re: Hoover HW6316M NDA
    iv had dry joints on the top board on hoover machines worth removing to check track side simon
    #252656
    Small board is the dryness module on this washer dryer. Fault can only be motor/wiring/core board. Cehck for burnt out joint around the relays.
    Turbo
    Thanks for the help,it was indeed a dry joint on the relay.
    Graham
