Hoover HWBOS69TAMCET-80 fill hose
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover HWBOS69TAMCET-80 fill hose
  • #102674
    washingmachinewoman
    This is machine id 31800973
    It had two fill hoses fitted to the bottom of the detergent dispenser, one goes to the tub, the other to the side of the door seal.
    The latter hose has sprung a leak, but I can’t find it listed. The exploded diagram on ASWO is a generic one. All I can find is the other fill hose and the sump hose. There are parts on http://www.hooverspares.co.uk (one of the many Connect sites) whose descriptions include fill hose but none of them are pictured or in stock.
    Anyone got the correct exploded diagram and parts list?
    #489981
    the hoover spares site seems to be down at the moment
    will try to think on to check later
    if i dont get back post a reminder
    washingmachinewoman
    Thanks Dave, will try to remember myself!!
    In the meantime, have sent a request on ASWO. There is also someone breaking this model on eBay, I’ve asked if they have the hoses.
    #489983
    ok try this
    seems to be a lot of hoses
    ok have emailed you the parts diagrams and the above screen dump
    if you need a part no not listed let me know
    washingmachinewoman
    Thanks Dave, got them.
    It doesn’t look a bit like that machine I went to unfortunately!! And these are the diagrams that ASWO also have…
    Wondering if there are several entries under part position 273?
    Lucie
    #489986
    part diagrams on hoover are not very helpful somtimes
    on this one some hoses change with serial as well
    washingmachinewoman
    Bingo!
    Thanks so much, Dave.
    The serial number of the machine starts with 2206, so there are two fill pipes i.e. 273 and 273a, the part I am after is 43036963. Not in stock at ASWO though… but I’ll keep looking.
    I don’t often think or say this, but ASWO has been most unhelpful this time around. Presumably they have access to the hoover site like you, and I gave them the serial number, but no, they wanted a picture of the rating plate and of the original part. Obviously I couldn’t do that as I have made a temp repair to the machine and didn’t take the part off.
    #489988
    Aswo has the same problems little or no info to help you identify part from hoover
    Hi Lucie
    found a tech doc on the inlet system that may make things a bit clearer
    have emailed it to you
    washingmachinewoman
    Thanks Dave, most edifying.:)
