Hoover HWD120 – 80 washer drier PCB woes.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HWD120 – 80 washer drier PCB woes.
  • #43531
    aqualectric
    Hoover HWD120 – 80 washer drier. No. 31001037 0520 0281.
    The usual fault with Candy washer driers – condenser pipe ruptures; water everywhere. Annoying but not serious.
    Until……..the factory forgot to fit the water splash guard on the lower PCB and it got drenched. The result is a machine that will not programme. Switch on, set to program, press the start button and it stays on “Stop” but the door locks. 😕
    Both the lower board and the main PCB look fine, I’ve cleaned the connections and refitted the plugs; still dead.
    I am thinking main PCB: but what does the small lower PCB do? If it got water damaged would the main PCB be affected?
    I also cannot find the part number for the main PCB.
    Any help please!!
    Thanks,
    Steve.
    #277585
    Re: Hoover HWD120 – 80 washer drier PCB woes.
    09200694 – core board – programmed
    41014754 – dryer board.
    aqualectric
    Thanks, Chris!!
    Is it likely to have blown both boards? And why has the drier got it’s own stand alone PCB?
    Cheers,
    Steve.
