Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover Logic 1200 A3786
- This topic has 20 replies, 3 voices, and was last updated 15 years, 7 months ago by
juicehills.
August 23, 2010 at 7:50 pm #56742
juicehills
ParticipantHi, My Hoover Logic 1200 model number A3786 has started sticking when it comes to spin section of programme, is this likely to be mechanical or an electronic fault, or does anyone have any suggestions?
thanks for your helpAugust 23, 2010 at 8:18 pm #328664suedehead1
ParticipantRe: Hoover Logic 1200 A3786
hi,
it could be sticking for various reasons,
creasguard selected, foeign object in pump, blockage in pressure switch system.
its very unlikely to be the timer,
Plug out when checking.August 23, 2010 at 9:35 pm #328665juicehills
many thanks for your suggestions, it’s definitely not the creaseguard, at least switch not selected.I’ll check the pump, although it seems to empty okay. It seems to take a long time to travel from supercare (E) to spin (G) then stcks but can you tell me how to locate and check the pressure switch system.
Thanks again, greatly appreciated!
August 23, 2010 at 9:38 pm #328666suedehead1
its the plastic “bottle” type thing at the botom of the backplate, if its blocked the machine doesnt know wether there is water in it or not, if its blocked it wont spin even if its empty.
August 23, 2010 at 9:50 pm #328667juicehills
It does spin if the machine is turned off and then spin selected on it’s own and switched on again?
September 1, 2010 at 5:57 pm #328668juicehills
hello again,
I’ve taken the presure bottle off and in the pipe at the bottom end there is what looks like hard white silicone sealant, it almost looks as if it should be there, is this the case?The belt has also snapped, could this have anything to do with it?
Colin
September 1, 2010 at 7:03 pm #328669suedehead1
there isnt supposed to be any silicone sealant there should be a hole about 1/4 inch diameter that stuff is probably hardened soap and will almost certainly be causing the problem.
the belt going is a coincidence, if you are replacing the belt make sure you note where the couloured wires go to the thermostats.September 1, 2010 at 7:15 pm #328670juicehills
I didn’t think it looked right, many thanks for your advice, it’s greatly appreciated.
thanks again
Colin
September 4, 2010 at 5:44 pm #328671juicehills
Ah well, new drive belt arrived from trusty UKWHITEGOODS in double quick time and has now been fitted, silcone removed from from pressure bottle and everything reassembled 🙂
However a new problem has developed, it is taking in water but I don’t know where it is going as very little seems to get to the drum and there is only a very small amount being taken into detergent drawer and only enough to dampent the powder at the far end of the drawer. It also seems to be “humming a lot” (electrnic humming, not the smelly kind 🙂 The only thing that changed was removing the silcone, anyone have any suggestions?
I’m under pressure now as she who must be obeyed, says the washing is piling up :rolls:
Colin
September 4, 2010 at 5:52 pm #328672timdowning
The humming is probably coming from one of the valves. Have you kinked the cold or hot fill hose?
Unplug as always if you are going in!
September 4, 2010 at 5:53 pm #328673suedehead1
have you kinked the fill hose or is the water not turned back on fully.
September 4, 2010 at 6:04 pm #328674juicehills
I didn’t need to turn the water off and i’m pretty sure that the hose wasn’t kinked but I’ll check that out.
Do you think that perhaps the silicone was suppsed to be there to form some sort of resistance in the pressure system? i don’t understand how it works, so I have to rely on you guys.many thanks for the speedy replies.
Colin
September 4, 2010 at 6:46 pm #328675juicehills
Hoses definitely not kinked and water turned on. It has taken in water but very slowly and doesn’t look as if it is enough but it has begun to tumble eventually but there is something amiss!
September 4, 2010 at 7:14 pm #328676juicehills
Could it be that the macine has to run a couple of time to repressurise the system?
September 4, 2010 at 9:08 pm #328677suedehead1
no repressurisation. the machinewont tumble unless it has enough water in it, as tim said the humming noise is the water valves, the hoses are kinked, the taps are not on fully or you have put the hot and cold hoses round the wrong way.
