connect have triple valves pattern and genuine for the hotpoint washer dryer which wouls suit just make sure that the dryer valve is in the same place.
If you have the lid off and are looking at the front of the machine the trickle valve output is on the rhs. is that the same as a wd62? A8552 is the model number. otherwise i need to get some hose.
The hotpoint original, IIRC, has two restrictors in the valve. What I always do is go for a pattern valve which has no restrictors in, then carefully cut out the restrictor from the old valve and tap firmly into the correct port of the pattern one.
Been a while since I needed a triple valve but Im sure the last one I got was from homespares.
