Hoover maxi 6 dryer
  • #40234
    skip
    Hi need some help can someone tell me what might be the cause of the squeaking from my tumble dryer as it turns, and how I might fix it
    Mod=TV20 001
    Serial no=3761522600084192
    Type=TVM01
    Thanks Skip
    #265210
    Re: Hoover maxi 6 dryer
    skip wrote:Hi need some help can someone tell me what might be the cause of the squeaking from my tumble dryer as it turns
    Ah that’ll be the famous ‘TV squeal’ caused by those infernal drum support wheels at the front. Usually squeals worse in one direction then gets so as the whole street are aware that you’re using the tumble dryer! :rolls:
    3 in 1 oil can time……oh yes! 😉
    #265211
    skip
    Thanks for the reply, how do I get access to these wheels
    #265212
    The front of the machine comes off – innumerable screws. BE VERY CAREFUL there are lots of wires and we will not be able to help you put them back if you pull them off……….
