Hoover Microwave Oven Door Springs
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hoover Microwave Oven Door Springs
  • #100966
    Twoten
    Can someone provide a part number for the door springs for a Hoover Microwave Oven
    HMC440TX 38900043 15270075
    Thanks.
    #482860
    cant see the spring but i may be looking in wrong place
    sent you a pdf
    Twoten
    electrofix wrote:cant see the spring but i may be looking in wrong place
    sent you a pdf
    Thanks Dave, The spring on this is located behind the small removable panel on either side (No. 207).
    The only thing that looks like it is slightly above the hinges 181a & 182a, but looking at the images on connect that relate to these hinge part numbers, the spring isn’t included.
    The closest I’ve managed to find is searching for the spring and removing the ‘TX’ from the model in the search which gives me this https://connections.connect-distribution.co.uk/cv6/product.pl?pid=3716260.
    #482862
    yes did some digging and found that spring part no 49022472
    bad new is there are 5 models listed starting HMC440TX and this spring is listed in all the others but not yours. by the looiks of the diagrams the hinge assembly is different
    see pics below
    cant you reform the end of the spring and refit ?
    Twoten
    electrofix wrote:yes did some digging and found that spring part no 49022472
    Thanks for looking into this Dave.
    The original spring went under guarantee. Hoover went out to it but could get the appliance out of the housing because the cable was too short.
    The spring is fairly heavy duty, I think it would be difficult to reform and if shortened, will over stretch it when pulled taut. The side that hasn’t broken loks like it’s overstretched
    If I can’t get a replacement it might be the only option though. Maybe reforming it and adding a metal hook to extend it might work.
