Hoover module please
  • #39817
    hotpnt
    Hi, anyone know where i can get part number for top main module on a hoover HFM160E?, other numbers on label are 31000324 0337 0185
    thanks, nothing listed at qualtex or connect
    #263706
    Re: Hoover module please
    First the good news…………………..41005340 😀
    Do you want the bad news?…………. 😥
    The module isn’t pre-programmed so you’ll need the Hoover laptop, computer programming what’sitsname to bring it into life!
    What’s blown on the module board anyway?….Triac maybe?….What’s it’s number (on the board)…do tell? 😉
    #263707
    hotpnt
    well thats a pain in the ar5e, the pump was o/c, fitted new one last week, all was fine, (though the motor connectors looked liked they had overheated or got wet), all fine over the weekend, then today it stopped puming again, tested it & there is 178v permanently to the pump, even on fill, but never 240v on drain/spin, took module out & seem to be a few tracks no longer attatched to board,
    so is hoover even worse than indesit then? ie there is no point even buying a module if it cant be programmed??
    #263708
    hotpnt
    and what would Hoover charge for their call out (plus parts of course) to a 6 year old machine?, i smell an ISE oppertunity arising!!
    #263709
    hotpnt
    ooh nice, i see thier web site says £99.50 plus parts!!, (feel like im talking to myself here!)
    #263710
    timdowning
    Typing your product number 31000324 into connect brings up a programmed module for your machine. give hoover a call in the morning.
    (20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} discount over the phone, trade discount)
    01204 556111 ask for Howard, very calm and helpful man.
    #263711
    helo_75
    yup, and i know howard, used to work for his mate
    and the direct tech number isnt that
    u got a pm
    #263712
    timdowning
    Very true. I was giving him the spares number!!! :rolls:
    #263713
    hotpnt
    cheers guys, much appreciated
    #263714
    97923189 – core board – programmed.
    helo_75
    does this machine have an anti loss hose?
    if it has, id be checking that first
    #263716
    hotpnt
    a what hose now??? 😕
    #263717
    helo_75
    ajn anti loss hose
    its a small black hose from the base of the dispenser to the pump
    on some earlier models, that rubbed on the weight, and a small hole sprayed a fine mist of water over ther pump , which caused th e problem u have
    just a thought, ive been and fitted a 2nd board before i found it – costly mistake
