Hoover New Wave 1100 Washer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover New Wave 1100 Washer
  • #46905
    jomas362
    Hi Guys
    We have a Hoover New Wave 1100 Washer Model AC170 Serial No AC17030500445 year of purchase 1993. It’s been working quite well apart from the odd leak here and there but now the drum motor doesn’t work. The machine runs through cycles, filling and emptying but at no point does the drum rotate. The belt’s OK, the motor doesn’t run. I had motor off and checked brushes, they are in good condition, move freely and springs are OK, no burnt out smells anywhere. Don’t know how to bench test the motor so put it back – still won’t run. Checked pressure switch and although I don’t know exact operation, the contacts open and close if I blow in to the tube connection point. Can anyone give me advice on where to look next and what might be the cause of this problem? Your help would be appreciated.
    John
    #291347
    bzz67
    Re: Hoover New Wave 1100 Washer
    check the wiring loom to motor, sometimes the lower concrete weight wears though the wires. with the plug out of course.
    #291348
    helo_75
    plus the switch on the front pressing of the drum.. sometimes the wire breaks there as well
    there where 2 variants of this machine, on was run just off a board, one was run off a board with a slave unit
    the easy way to tell, is if you open the door, do you get a . or 3 bars?
    dont be surprised if the slave unit is faulty if its the latter
    oh halcien days.. fitted rakes of them when they were in production.. dont see any these days
    #291349
    suedehead1
    most likely a dry joint on the pcb.
