Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover new wave plus 5
- This topic has 5 replies, 3 voices, and was last updated 21 years, 1 month ago by
admin.
February 22, 2005 at 8:27 pm #8098
KeymasterI am having difficulty with my hoover new wave plus 5 (A2140-001)
Having replaced the brushes on the motor the machine will run on a program 10 (fast spin) ok. Problem is when trying to run the likes of a prog 4 the m/c will fill ok but when motor tries to turn all I get is a buzzing noise. It will go through the cycle and when ever fast speed is used on the motor it goes OK. It will run through the whole prog ok and drain ok. ❗ ❓ ❓February 22, 2005 at 9:44 pm #126865Penguin45
ParticipantArmature losing the will to live I’m afraid. Not even sure if the motor is still available – Dave Conway’ll know, ‘cos he’s clever at these things.
Penguin45.March 8, 2005 at 8:55 am #126866admin
KeymasterRe: hoover new wave plus 5
Hi:-
Thanks for that.. I have now managed to obtain a replacement motor which gives me both speeds.. The problem I now have is an’E2′ error.. I’ve cleaned the ball and the sump and checked for blockages. the error happens midway through a number 4 program cycle. The machine will do a quickwash(12) and a fast spin(10) without going into error condition. could anybody give me some advice… thanks…March 8, 2005 at 9:06 am #126867Martin
ParticipantRe: hoover new wave plus 5
petermac wrote:The problem I now have is an’E2′ error..
Your Heater is the guilty party this time 🙁
available (Part No 09074618) if you email : – spares@ukwhitegoods.co.uk
(Copy & paste this post to the email though)
March 9, 2005 at 9:02 am #126868admin
Tried making sure the connections hadn’t been disrupted when changing the moter.. they all looked OK.. but reseated them at element end just in case…The machine timed out again 1st time I tried(prog 4) but went through a complete cycle(prog 4) the next time. Havn’t tried again.. If/when I replace the element what is the best way to tackle it.. Should the font panel be removed.. Or is there enough room to remove from underneath. Your help is very much appreciated…
March 9, 2005 at 9:15 am #126869Martin
petermac wrote: Should the front panel be removed…
:tup:
