Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover new wave plus 5 model no AC17840100158
- This topic has 8 replies, 3 voices, and was last updated 18 years, 1 month ago by
paulipm.
February 25, 2008 at 2:11 am #34829
paulipm
ParticipantHI
The problem I have is the machine gives error code 1 I have found the water heater is not coming on everything else is working (it filles with water the drum turns the spinner works and the pump works fine ) , the element measures ok using a multimeter , what I have found is that the thermistor reads 8 mega ohm when cold and drops to 6 mega ohm in boiling water what I am unable to find is the range these thermistors work in the thermistor is reacting to heat but varying between 8 and 6 M ohm seems very high to me .Can any one helpFebruary 25, 2008 at 6:36 pm #244164helo_75
Participante1 on a new wave is usually the heater being slightly down to earth
do you find the machine wont spin either?
change the heater, im sure all will be fine
Power off, first.
February 25, 2008 at 11:54 pm #244165paulipm
ParticipantRe: hoover new wave plus 5 model no AC17840100158
No it spins ok .Checked the element out with my megger definately no earth fault .February 26, 2008 at 8:33 pm #244166helo_75
Participantfill it full of water, let it run for 10 mins, and try it again
February 29, 2008 at 12:15 pm #244167paulipm
hi
definately not the heater , meggerd it with the m/c full of water no earth fault in any cause if there was an earth fault then the house elcb would have tripped, I still suspect thermistor or card .February 29, 2008 at 3:34 pm #244168helo_75
dont kid yourself
earth leaks dont always trip the pcb
when you open the door, does it have 3 lines or just a dot?
March 1, 2008 at 12:36 am #244169paulipm
hi
Theres a row of dots flashing ,also I hard wired the heater and it heats up ok bypassing the washing m/c control c/c . ❓March 1, 2008 at 4:06 pm #244170timdowning
Have you checked the wires to the heater? They can break on the right side where the wires go from the machine to the tub. They can break very neatly so don’t just visually check them physically check as well.
Power off. Unplug machine as always.
March 2, 2008 at 12:23 pm #244171paulipm
Yes continuity is fine on both wires , no breaks or intermittant breaks -
