Hoover Nextra 6 HNL 7146
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Nextra 6 HNL 7146
  • #80046
    tallpaul
    Back again after a few years off!
    The washing machine suddenly stopped working last week. It had water in the drum so I suspected the pump. Took it off and changed it for one I know to be good – from another working machine. Tried again. On a spin only cycle it drained the water nicely – no problem with the pump then.
    This morning I tried running a ‘Daily 29″ program, the washing m/c filled as normal but would not rotate – there’s a double ‘click’ indicating to me that its trying to send a signal to the motor to start but nothing happens. I suspect the motor.
    Question; before I remove it are there likely to be any other causes? I don’t seem to have any error codes, i.e. there are no flashing lights – the only light on the board is the 30min timer light which I believe is normal for this m/c when its operating.
    #411472
    Re: Hoover Nextra 6 HNL 7146
    The motor brushes need replacing.
    #411473
    tallpaul
    thanks done and working again.
