Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover Nextra D/W no heat
- This topic has 14 replies, 5 voices, and was last updated 15 years, 1 month ago by
iadom.
March 4, 2011 at 5:00 pm #61465
ModeratorHND6515-80 Error codes checked but this machine has no digital display?
Anyhow, checked element which is fine, found the small central switch ( overheat switch ?) is O/C.
Going to order a 41020658.
Question, how does it come out, prised out from underneath or released from inside the tub?????
March 4, 2011 at 8:43 pm #346270loopey
ParticipantRe: Hoover Nextra D/W no heat
no just unscew it , its a pressure switch, it is o/c till pump runs like the whirpool
n smeg dishwashers that get clogged up . check the ntc probe has not come awayits hard to see as its located at the front of the sump a pound to a penny pcb has a a dry joint or goosed , or door wires o/c
hth
philMarch 4, 2011 at 9:34 pm #346271iadom
ModeratorRe: Hoover Nextra D/W no heat
Thanks, will check those out. 😀
March 9, 2011 at 3:55 pm #346272iadom
Back at this machine this afternoon, wiring and PCB both look OK.
Just printing off the test routine.
What are those weird screws in the door etc called? At first I though they were normal torx screws but they are not.
I managed to get them out using a flat bladed terminal driver but it wasn’t easy, never seen them before.
March 12, 2011 at 12:09 pm #346273iadom
Still struggling with this thing.
It has Nextra on the front and all of the buttons are square, not round.
Model HND6515-80..32000291-0629-3189I tried the test routine (Tech note N.802 LS ) but could not get it into a test routine no matter how much I tried.
looking at the parts list it shows four different control PCB’s, this one sits at the inside centre of the door panel.
I am reluctant to throw a PCB at it on the off chance it works but everything else checks out.
Just in case the customer agrees to it, does anyone know exactly which PCB is needed for this machine, approx price as well if possible.
Thanks.
March 12, 2011 at 10:07 pm #346274iadom
Anyone????
March 13, 2011 at 3:00 pm #346275iadom
The daily bump. 🙂 Hopefully someone will know the answers to my questions afer the weekend.
March 13, 2011 at 8:21 pm #346276bruce118
Had oneon a Hoover that would not heat, re soldered the relay connection on pcb , and this seem to cure it! Have not been back – some months ago. the connections looked fine but often try this first as has worked on other dishwashers Too – but not always.
Worth a try then test by putting on to a quick wash as will heat right after fill. Hope this works. BruceMarch 14, 2011 at 9:53 am #346277iadom
Thanks for that.
I would still like to know which of the four possible PCB’s is the correct one for this model, surely someone must have an idea?
March 14, 2011 at 12:24 pm #346278Martin
iadom wrote:I would still like to know which of the four possible PCB’s is the correct one for this model, surely someone must have an idea?
The correct Power Board = 41016753
March 14, 2011 at 4:05 pm #346279iadom
Thanks Martin, you wouldn’t have any idea of approx cost. Its special order POA at Masterpart.
March 14, 2011 at 4:44 pm #346280Martin
In stock at Connect at about £35 trade.
March 14, 2011 at 4:52 pm #346281iadom
THanks again, BTW what do you use to get those pesky screws out of the door panel etc?
March 15, 2011 at 2:05 am #346282gandh1
a drill 😀
are they the security torx with the pin in the middle?
March 15, 2011 at 10:03 am #346283iadom
No, they seem to be a cross between torx and phillips slots.
You cannot fit any size of torx or phillips driver in them, I had to try several different flat bladed drivers and it was very difficult to remove some of them. 😥
