I have a hnl 6166 nextra
a week ago it had a stuck sock in the pump, remvoed it and it was fine,
Now this weekend, it has started to play up again.
It starts the cycle water enters,
And takes in the washing power then
after that it just sits idle
You can hear a click but it does not the turn the drum.
I removed the motor and check the brushes they had more than 1/2 inch left on them.
on the connector block one of the red wires, (live ?) had come off, i soldered this back on, and checked it had continuity to the motor and all else was fine,.
What other things can i investigate ..
And could this be an issue with the triac ?
thanks
