Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover nextra hnl 662 80
- This topic has 10 replies, 3 voices, and was last updated 14 years, 6 months ago by
stevie w1.
September 19, 2011 at 4:25 pm #65144
stevie w1
Participantmachine wont dispence water , i close the door select settings from controller press start ,door lock comes on but water dose not go into soap dispenser i have check mains water supply all ok
September 19, 2011 at 7:22 pm #359260iadom
ModeratorRe: hoover nextra hnl 662 80
Will the machine drain and spin?
September 19, 2011 at 9:04 pm #359261stevie w1
ParticipantRe: hoover nextra hnl 662 80
starts a spin cycle then stops about one min. starts as if it is going to a full spin then stops door lock still on setting is 15 on front of machine does not seem to drain
September 19, 2011 at 9:34 pm #359262iadom
Could be a faulty drain pump, quite common to get leaks onto the pump, can often lead to failure of the main PCB. 🙁
September 20, 2011 at 1:49 pm #359263seagull
stevie w1 wrote:starts a spin cycle then stops about one min. starts as if it is going to a full spin then stops door lock still on setting is 15 on front of machine does not seem to drain
open circuit drain pump most likely
September 20, 2011 at 7:21 pm #359264stevie w1
do you get cotinuity across the two spades of the drain pump
September 20, 2011 at 8:57 pm #359265iadom
It depends on what you are testing it with but resistance should be around 160? to 180?.
September 20, 2011 at 9:51 pm #359266stevie w1
tested with a fluke. pump goost . will order one cheers ,thanks for all the info hoover engineer wanted 169 pounds as my warrenty had just run out Being and old miserable heating engineer didnt want to part with that amoumt of money ..cheers
September 20, 2011 at 9:55 pm #359267iadom
If you are lucky it will just be a faulty pump. Look closely for any signs of water ingress. It shouldn’t really be happening so soon but the inlet hose from the dispenser to the drum can leak where it slots into the outer drum.
You should also make sure the replacement pump has an internal TOC, some don’t and if the pump gets jammed they will often take out the main pcb if there is no overload protection.
September 27, 2011 at 5:49 pm #359268stevie w1
wasnt lucky, got new pump ,fitted still no water at solnoids ,but drum would now spin. had to buy PCB. cheapest was candy/hoover to my suprise .PCB fitted machine working like a goodning still hate hoover thanks again for the advice iadom and seagull
September 27, 2011 at 6:20 pm #359269iadom
stevie w1 wrote: still hate hoover
Perhaps you should direct your ire at Candy, thats what your machine is after all. :rolls:
