Washing machine working fine until failed to start…checked filter for obstructions clear small amount of water so pump had emptied as normal…does not matter what programme selected same result..instructions state when turned on stop light flashes select programme press start.. stop light illuminates door locks and door light illuminates…ain’t happening..when you switch on stop light continually illuminated (not flashing)obvious power to control board…having read forum changed door interlock still no go..checked door hinges and jiggled door handle when closed no change…forums suggest control module damage have removed both and checked for obvious damage using magnifying glass..nothing obvious continuity check on boards suggest all working ok.. ie. resisters diodes ect..certainly no blown components or track lines..continuity on blue and brown wires from power capacitor/suppressor seem ok new door interlock is a newer version eg push fit wired the same …green wire to position 1…white to position 3 and brown/pink to number 2..
presumes it would be the same as old lock…thanking you for any advice..
