Hi Pee’d off busy mum :o)
WOW, we’re like 2 peas in a pod.
Sometimes I have to start the drying program 4 or 5 times for it to work. It clicks and humms for a while then clicks again and stops. I know if it has started OK when the red “drying” light above the dial is lit.
Anyway, that I can live with (well, sort of). Mine keeps cutting out and blowing out cold air. I’ve had the lid off and pushed the reset switch. It clicks down, then blows hot again. It keeps need resetting though. What was your problem? I’ve removed the metal flow pipe where the switch sits and its clean inside.
Just wondered if you could shed any light?
Sorry to go on………
