Hoover Nextra – Replace the Main Programme Board?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Nextra – Replace the Main Programme Board?
  • #39054
    jhnby
    Hi there,
    I have a 4 yr old Hoover washing machine Mod. HNF 3157-80 / Ser. No. 3100063 0445 4563.
    On a 59′ wash programme, it remains on wash for hours without moving on to rinse, drain or spin.
    On a rinse cycle, it will fill and drain and keep tripping at the same point in the programme til it turns itself off.
    On the spin cycle, it drains for a long time, the drum twitches occasionally and then it stops without spinning at all.
    I’ve cleaned the pump of the few calcium pebbles – (otherwise clean) and checked all electrical connections.
    A couple of days ago, it wouldn’t drain, but did spin with some water still in the drum. Now it won’t spin, but it drains ok. I’m confused!
    Any ideas what I should try next?
    #261132
    suedehead1
    Re: Hoover Nextra – Replace the Main Programme Board?
    have you checked the motor brushes,
    plug out first.
    #261133
    jhnby
    Will I have to take the motor off to do that? From what I can see, there seems to be a light covering of black dust over the copper segments. Could it just need a cleaning?
    #261134
    suedehead1
    dont clean the coper segments.
    take the brushes out and look at the faces both should be shiny.
    #261135
    jhnby
    Yes, both faces are clean and shiny. One shaft surface looks like it has been affected by heat. (1mm in total from the face).
    #261136
    jhnby
    So I wiped the stem clean, put the brushes back and put the motor back in. Is there anything else I could check before ordering a new programme board?
