Hoover Nextra6 Washer/Dryer Model: HNWL 7146-80 Help Required Please…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Nextra6 Washer/Dryer Model: HNWL 7146-80 Help Required Please…
  • #97337
    Jackie Eades
    1st Thank you for the add to the group, I’m looking for some help please, I haver the above Washer/dryer with Fault Code 09 which i am led to believe through reading that this code is meant to be ( triac on the main control module.) Please can someone advise to confirm this or point me in the right direction to the part I require. If anyone can help a picture of the part would help. I hope i have wrote it so you understand me ? If not please advise Thank you to everyone for reading and any help along the way,
    #467106
    the E09 code relates to a small electronic switch on the main control board called a Triac. the fault code is saying this component is faulty. to be able to change this you would need to be able to solder small components into a circuit board
    Also just because the fault code occurs does not mean this is the actual fault. it could also be a faulty motor or a fault in the board causing this
    If i had this fault i would check the component with a multimeter to see if it was short circuit before i investigated further
