Ok, back again with my aging OPH714D – bit of a Triggers broom this one – not much of the “old ” machine left…
This time the pump isnt running, will run a cycle but not drain.
cleaned the pump and pipes, no problem found. Also checked the pump with direct 240v and all seems well, so its not receiving power.
– can this be caused by anything other than a faulty pcb?
Anyone know this? I have a hoover machine with the same fault sat in the garage, was a spare machine, i also thought it may be component on PCB at fault?
