hoover oph 614
  • #80277
    delta01
    hi just replaced control panel now it just does initial fill then stops
    flashes light 2 times i dont have fault codes for this model any suggestions appreciated
    thanks john
    #412328
    Re: hoover oph 614
    Error codes for the ‘Optima’ series ARE in the Known Error Codes thread. 😉
    2 flashes normally would be ‘Fill time out’ if my memory serves…….?
    #412329
    Redframz
    Re: hoover oph 614
    Done one yesterday with the same fault changed the water valve, the diaphragm in it had a tear in it.machine now ok
    #412330
    delta01
    Re: hoover oph 614
    thanks guys turned out to be pressure switch gave it a knock with screwdriver and it started filling to level found it faster to get error codes by just putting a search on google
    #412331
    Re: hoover oph 614
    delta01 wrote:found it faster to get error codes by just putting a search on google
    Whatever dings your bell but Google don’t have access to many of the error codes we put out in the trade forums. So using the search facility here tells you more than Google would ever!
