Hoover OPH, VHD & WMH + Candy models
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover OPH, VHD & WMH + Candy models
  • #72694
    AJC_Dave
    I seem to get loads of these washing machines with the same error where program selection goes all over the place and after a while doesn’t select a program at all.
    I was wondering if anyone knew what component/s cause this on the board and why it does it? Also, is it something that can be repaired?
    AJC_Dave
    Re: Hoover OPH, VHD & WMH + Candy models
    Found the answer!!….thanks anyway.
    #385288
    AJC_Dave wrote:Found the answer!!….thanks anyway.
    Oh, do tell, was it the selector switch?
    #385289
    AJC_Dave
    Yep… someone else had a similar post. should have looked first!
    #385290
    AJC_Dave
    Sorry to bring this back up….
    Must do at least one of these a week and having little success in repairing the selector so have been replacing the full facia pcb. I’ve used pcb cleaner on some and its worked but with very limited success.
    Does anyone have any other methods or is just a case of replacing?
    Replace every time, switch cleaner only a temporary fix at best and should only be used as a ‘get out of jail card’.
    #385292
    AJC_Dave
    That’s what I found. It improved some slightly but nothing on most.
