Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover – OPH616
- This topic has 8 replies, 3 voices, and was last updated 14 years, 5 months ago by
twicknix.
November 7, 2011 at 1:38 pm #66131
twicknix
ParticipantI found this thread elsewhere with similar problem I am experiencing on the client’s machine. “We end up with 3 flashing lights (no apparent code it just keeps flashing) the lights are no spin, 3 h and door security”
The machine is about 18 months old, client did not want to call out Hoover. I carried out the electrical test, low insulation, tracked it down to the motor being dirty, cleaned it out, insulation is now way high just how I like it. Heater is fine and drain pump is fine too.
Did functional test, attempted to select spin cycle to re-bed the brushes as it was removed when I was cleaning it. The machine went into drain out and would not stop. The lights flashes just like what it was said on other thread. The door would not open after 5 mins after it was switched off. Gave it a good thump and it opened. Me thinks it’s door interlock fault, what you reckon?
I have bought the interlock to try out tomorrow along with new carbon brushes for good measure.
November 7, 2011 at 5:28 pm #363184jrrepair_2000
ParticipantRe: Hoover – OPH616
Whats the first 8 numbers of the serial no.
November 7, 2011 at 6:35 pm #363185twicknix
I wish I could provide the serial number but the owner peeled of the label! Where else do I find the serial number?
November 7, 2011 at 6:40 pm #363186BobHope
there is sometimes a sticker on the rear.
Bob.
November 7, 2011 at 7:13 pm #363187twicknix
Believe me, I did check for it. It’s been cleaned off too! I do not know why people would do that!
November 7, 2011 at 7:19 pm #363188BobHope
the only way now is to read it off the pcb module with a memloader.
Bob.
November 7, 2011 at 7:36 pm #363189twicknix
I appreciate the input, I am having enough troubles with Hoover washing machines. I dealt with two today with similar original faults, the OPH one is more messed up and I will try resolve it by replacing door interlock and carbon brushes.
The other one a Nextra which is about 10 years old, easy to diagnose – buttons fell through which was typical also needs new door seal but parts seems rather thin on the ground and getting mixed result on type of brushes and the lack of cross references. (I will have to buy each set and hope for the best!). It was the carbon brushes worn with low insulation causing the weird washes like I said similar fault as the OPH.
When there’s a will then there’s a way! I will get to the bottom of it!
November 7, 2011 at 7:42 pm #363190BobHope
if you want some info on the motors and brushes pm me your mail address and i will send some usefull info.
Bob.
EMAIL SENT.
November 8, 2011 at 12:30 pm #363191twicknix
Turned out that it was the motor causing the mother of all problems. Low insulation on motor although I cleaned it up yesterday and re-tested it but not it gone back to low insulation again. Client says don’t bother.
