Hoover OPH616/2-80 prog locked up
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover OPH616/2-80 prog locked up
  • #75411
    Bernie
    Hoover OPH616/2-80
    The 3hr, cold wash & Aquaplus LED all flashing, no pause, just flashing.
    Cannot select a program, when you switch machine on it starts to fill straightaway
    Customer did say that on the last wash it got very hot.
    I have got the Hoover Optima fault codes, but as there does not appear to be one that does not help.
    Anybody got any suggestions please
    Bernie
    #394843
    timdowning
    Re: Hoover OPH616/2-80 prog locked up
    Quite common to do this. Its not a fault as such its just locked up. You generally can sort it by cleaning the programme selector (been discussed on here many a time). As well as going mental twiddling the dial. Sometimes holding the start button & turning the dial, from OFF, back one click does the trick too.
    Or you could replace the board. Not too bad a price.
    #394844
    Bernie
    Thanks for the quick reply, will try what you have suggested
    The price for the Fascia control module from Connections is £117.80 + VAT with a SRP of £207.88 not that cheep.
    Bernie
    #394845
    Bernie
    I tried holding the start button & turning the dial, that did not work until as you say mental twiddling the dial whilst holding the start button that unlocked it. I selected spin and it spun but when I tried to cancel it, it locked up again. So I thought I would clean the program selector, only it is soldered to the board and no way to get into it. I have some Amberlube contact cleaning lubrication so I gave it a spray and again mental twiddled the dial this worked.
    Thanks for your help and suggestions
    Bernie
