Hoover OPH616 water temperature
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover OPH616 water temperature
  • #72436
    mort58
    I have a problem with the above model washing machine whereby when I put it on a 60 degree wash it only heats the water to about 30 degrees and when you put it on a 90 degree wash it overheats!
    Can anyone advise me what the problem might be and what part I need to replace.
    Many thanks…
    #384515
    Muv
    Re: Hoover OPH616 water temperature
    Its the NTC “water temperature sensor” this is located in the element itself, and is a push in fit..with a plug type connector around £10 to purchase at most…..check connections on the element itself are nice and tight, and show no sighns of over heating…if they do then change complete assembly which will come with the NTC sensor fitted ready..
    Muv
    Complete assembly is here
    http://shop.ukwhitegoods.co.uk/41021737 … ng-element
    mort58
    Hi Martin
    Many thanks for the reply,
    Can you clarify which sensor this is as having looked at photo of the element I cant see any sensor “in” the element fitting itself?
    Do you mean this one that sits above the element?
    http://www.hooverspares.co.uk/product/4 … /NTC+PROBE
    #384518
    Muv
    Yes, thats the one you need..
    mort58
    Thanks Martin..
    Ordered the part through yourselves.
    #384520
    helo_75
    …………..which is a waste of money
    faulty thermistor…. e5 fault
    faulty heater … no heat
    the selector dial requires cleaning
    #384521
    timdowning
    Blimey what temperature does it get to then. It must be bubbling away if its hotter than that. (Which if it did would cause the heater to go open circuit).
