I have OPH 714 showing error code E07. The machine seems to have completed the cycle but will not release the door at the end if it is showing this error code.Any ideas?
Hi: E07 is listed as a faulty door interlock switch or Jammed motor, please remember:
POWER OFF & PLUG OUT BEFORE CHECKING. Getting :zap: can seriously spoil your day.
If you don’t have the equipment or knowledge to safely check your machine, please call a good local engineer. You could try the UKWG repairs@ faciltiy to find an engineer local to you.
