hoover oph716df/l-80
  • #85768
    daveh2465
    Hi all I need some advice please my sister in law has had problems with her drive belt, it snapped a few weeks ago and a friend replaced this for her but since then the belt keeps falling off, I had a look yesterday and noticed the drum pulley was loose and wobbling all over , I tightened this and re seated the belt, I then noticed the belt moving to the rear of the pulley, on a test cycle it worked ok but once it went onto a fast spin the belt again came off, any suggestions will be greatly appreciated, I was wondering wether the pulley has somehow become buckled ? best regards Dave H
    #429503
    Re: hoover oph716df/l-80
    Sister in law belts falling off are a common problem these days. 😉
    The pulley is likely to be worn and her new belt less likely to fall if you replace her pulley too. 😀
    #429504
    daveh2465
    thanks Martin, I will let her know :rolls:
