Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover Oph7174D E03 fault help please
- This topic has 15 replies, 7 voices, and was last updated 16 years, 5 months ago by
MANDELLS.
October 23, 2009 at 3:51 pm #49564
MANDELLS
ParticipantGot the above washing machine which is only 18 months old, coming up with E3 (time out fault) checked pump thats ok, sump hose is clear, air switch working fine what else id there to check, please help as allways this a friends machine.
October 24, 2009 at 10:59 am #300239electrofix
ModeratorRe: Hoover Oph7174D E03 fault help please
you dont say exactly how fault transpires but have you checked water and valves ?
October 24, 2009 at 5:42 pm #300240MANDELLS
ParticipantRe: Hoover Oph7174D E03 fault help please
Sorry mate,
The machine starts the wash as normal, reaches temp continues to wash then drains ready for first rinse,then stops dead and displays E3.
What do you recon??????October 26, 2009 at 11:31 am #300241electrofix
would check cold valves first old hotpoint used to do this when cold valve failed
second check pressure switch unit if it is not dropping out machine will sense thisDave
May 24, 2010 at 7:37 pm #300242allan73
I know this is an old thread but i would like to know how this turned out, i have a similar m/c doing exactly the same ?
May 24, 2010 at 8:10 pm #300243timdowning
E03 drain time-out.
The one I had last week was a burnt out connector.
Normal things though, blockage, wiring or pump. Also check heater whilst you’re at it. (Low insulation can give you this error.)
Tim.
May 24, 2010 at 8:26 pm #300244allan73
Already checked the usual suspects, which connector was burnt out ? Im thinking pressure switch may be the culprit on this one seems to wash ok & drain then E03 displayed.
I will meggar element though. 😕May 25, 2010 at 10:25 am #300245loopey
Uploaded with ImageShack.us
This is what i found on this , hope it helps
A) DESCRIPTION OF THE TROUBLE:
We were recently informed about some seldom happenings of the trouble as quoted in subject, mainly
on Washing Machines and Washer-Dryers equipped with Electronic Power Modules of the “Cuore” type,
both by the MDL and INVENSYS makers.
In normal operational conditions, the ERROR 3 is displayed whenever the Phase of Drain is taking a
longer time than the maximum allowed 4′ and 30″. The most frequent reasons for the displaying of the
ERROR 3 are the clogged Filter of the Drain Pump, the bent and/or clogged Drain Hose, an obstruction
in the wall drainage system and of course a defective Drain Pump. On the contrary, in the here
mentioned cases the ERROR 3 was randomly displayed by Appliances whose drain circuit was in perfect
conditions and whose Drain Phases were carried out within the designed limit of time. Nevertheless,
the ERROR 3 was displayed and when this happened, the currently running Washing Cycle was halted.
B) REASONS AND SOLUTION OF THE TROUBLE:
After a careful examination, we realized that the common factor to all
Appliances showing the trouble as in subject, was a slight current leak
on the grounding of the Water Heating Element, this sending a
misleading signal to the “Cuore” Power Module.
Therefore should you happen to face a trouble like the above
described, we suggest to disconnect, insulate end safely fix far
from the moving parts, the two connectors of the Water Heating
Element (indicated in the picture). Next, carry out a whatever short
Washing Cycle with a Phase of Heating.
In case of INVENSYS Power Module, the ERROR 14 (Missing Water
Heating: defective NTC Probe and/or Water Heating Element and/or
Wiring) could be displayed. Contrary to what happens with the ERROR
3, ERROR 14 doesn’t halt the currently carried out Washing Cycle.
Should the Washing Cycle be correctly brought to the end, without any
ERROR 3 being displayed and being all the Drain Phases correctly
performed, then please replace the Water Heating Element with
another one of the same type and supplied by GIAS as spare part.
Best regards.
GIAS ItalyMay 25, 2010 at 11:04 am #300246allan73
Can i not just test with my insulation tester rather than trying to run it with the heater disconnected ? 😕
May 25, 2010 at 7:31 pm #300247allan73
Sorry fogot to say thanks for the info Loopey 😳
May 26, 2010 at 11:17 am #300248loopey
no probs fella.
have found changing the heater sorts it out, even iff theres no low insulation showing …
phil
May 26, 2010 at 4:32 pm #300249bw
Have had similar problems on hoover before, almost always earth leak on heater.
May 26, 2010 at 8:30 pm #300250allan73
Looks like i’m gonna be ordering a heater ❗ Thanks for the help guys.
June 9, 2010 at 10:08 am #300251allan73
Just updating this, fitted heater last week and so far no word from customer so i assume all is well 8) Strange thing is though when i insulation tested the heater it was perfect 😕
June 9, 2010 at 2:38 pm #300252helo_75
Participantthey do tend to go down under load, usually when theyre warm, and have powder on them.. hoover heaters have done that for yrs
