Hoover Optima OPH614-80 Error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover Optima OPH614-80 Error code
  • #71033
    Latham63
    Machine fills on drain and spin cycles + will not drain at all.Pump/motor/heater checked ok. Replaced pcb only to find that cold wash led flashes 15 times then stops,cycle repeats flashing sequence.Door lock activates,otherwise machine is locked into this error code?Mmmmm…
    #379819
    Muv
    Re: Hoover Optima OPH614-80 Error code
    Sounds like a faulty fill valve or pressure switch to me?
    Latham63
    Turned out 15 flashes = pcb not programmed. The pcb I received was supposed to be programmed(apparently not!) Ordered another,which was progammed.Machine ok now!
