Hoover optima oph714d
  • #62814
    colly
    Just at a Hoover optima that is allowing the door to lock.
    All display is ok and can set programmes fine.
    But machine just sits there with the door lock led flashing away .
    No flashing lights .
    Any idears ?
    Coly
    #351396
    Re: Hoover optima oph714d
    colly wrote:But machine just sits there with the door lock led flashing away
    The Door Interlocks (Pt No: 41016879) are a regular fault on these machines. But I would take a close look at the main module just in case the interlock has blown the triac on the board?
    #351397
    cornwell40
    Yup. I concur, had a couple doing the same, door switch and board rectified it.
    Tony
    #351398
    colly
    Hi guys
    Thank you for your replies .
    I do keep the door lock in stock so was going to fit it on my return visit .
    I have already ordered a new mod £29 plus vat , not a bad price I thought .
    Will post when I have fitted them ,just to update post .
    Colly
    #351399
    colly
    Hi guys
    I fitted a new pcb today also a new door interlock.
    On removal of old pcb you could see a couple of blast marks.
    Machine now working fine .
    Colly
