Hoover Optima OPH714D fault codes f03 and f16
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover Optima OPH714D fault codes f03 and f16
  • #58545
    boselecta
    Hoover Optima washing machine drains and heats ok but cust says every wash shows either f03 which is a drainage fault or f16 which is a no heat fault.
    Any ideas?
    #334875
    alro
    Re: Hoover Optima OPH714D fault codes f03 and f16
    had this fault fo3 heater worked ok but a small insulation down on heater changed it machine worked fine
    cheers alro
    #334876
    loopey
    yep just change the heater and all will be well very common on these m/cs
