Hi after reading all the information on your site re: problems with washing machines I am assuming my problem relates to the drum bearings, have taken off the back of the machine and when turn drum manually it is noisy. Just checking whether it is possible to replace the bearings etc. after reading that some machines have sealed units. If it is repairable could you let me know if the drum can be removed from back of machine or does it have to come through the top. Once I know I can give your spares department a ring and order everything I need. Thanks
Thanks for your replies, either way probably not worth repairing even if only cost 129.00 think i would rather put that towards a new washer, good to know about the sealed unit though I’ll double check which machine is the easiset to mend before I buy next one. Thanks.
