Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hoover optima oph714d
- This topic has 33 replies, 12 voices, and was last updated 16 years, 3 months ago by
darknez.
May 30, 2011 at 10:40 am #306617
helo_75
ParticipantRe: hoover optima oph714d
see previous post made by me!
May 30, 2011 at 4:58 pm #306618Applianceman2010
Just if you need a little more encouragement i had one last week exactly the same problem,changed heater works perfectly now.It was covered in limescale. Hope this helps 😀
June 10, 2011 at 8:47 am #306619itsbroke
More help please…
I have the same problem, same machine, 18m old,
runs fine, gets to drain, E03, (although it is empty), then E16.
I’ve changed the element as suggested, cleaned the pump, hoses etc (no blockage found) no difference.
How does this machine detect water in the drum? is there a sensor/ pressure switch somewhere – if so where?!?!
(I can’t find anything that looks like a pressure switch – where should I be looking??)Is the sensor at the back of the drum above the element just a thermostat, even though there’s a connection on the element that is marked thermostat?
It does seem like a water sensor fault rather than anything else but I can’t see how it determines the water level?
Help please !!!
June 10, 2011 at 9:15 am #306620kwatt
KeymasterRe: hoover optima oph714d
Item 153 on the attached.
There are several versions of this machine, seven actually, sold in the UK and one in Europe so I’d need the correct and full model number, possibly the production code both from the rating plate and nowhere else, to look at parts for you.
HTH
June 10, 2011 at 9:35 am #306621itsbroke
Thanks for that, that diagram is useful!
Details are:
OPH714DS/1-80
N. 31002670 0830 0858
Type FCE2
1400rpm
IPX4Made in Italy
Sold by CometJune 10, 2011 at 10:35 am #306622June 10, 2011 at 10:54 am #306623itsbroke
Really helpful – Thank you
June 10, 2011 at 5:57 pm #306624itsbroke
Found the pressure switch, removed it, dismantled it,replaced it… no difference..
the diaphram is good, contacts clean,the pipework is clear – it seems to operate ok. so I guess its not the pressure switch then?
Am I right thinking all thats left is the circuit board?
– or is it worth trying a new pressure switch anyway?Current symptoms are that it runs fine until it goes to drain. then it drains, stops a moment and begins to drain again, but there’s nothing there so get E03. (don’t get E16 anymore)
If you leave it overnight it will often work perfectly next morning for 1 run only, then it gives up…
before it goes to the tip should I try anything else???
June 10, 2011 at 8:40 pm #306625Applianceman2010
Have you cleaned out the pressure pipe and into where it connects to the drum?
June 11, 2011 at 12:10 pm #306626itsbroke
Yes – all clean,no sign of blockage…
June 11, 2011 at 10:26 pm #306627Applianceman2010
Hummm sounds like either a PCB fault or pressure switch,if I was a betting man I would say PCB but pressure switch is the cheapest option to try first even though it is very rare that modern ones fail hth DJ
June 13, 2011 at 11:21 am #306628itsbroke
Ok, will order one.
interestingly, it will now run a complete (but empty) rinse cycle with no problems, the minute you put on wash cycle
problems start. have tried various detergents (thinking about foaming) – doesn’t seem to have an effect..June 13, 2011 at 12:08 pm #306629Martin
itsbroke wrote:If you leave it overnight it will often work perfectly next morning for 1 run only, then it gives up..
The pump is DUFF….!!
June 13, 2011 at 3:20 pm #306630itsbroke
Hi Martin,
The pump seems to be the only part that does work,
why do suspect it?
– there’s never any water left, just that the machine thinks there is?June 15, 2011 at 11:43 am #306631itsbroke
For anyone who wants to know the final outcome..
Long story short – chance meeting with someone “who knows these machines” guaranteed me the element was at fault.He told me that the elements are quite delicate and that sending them through the post without good packing can wreck them (I bought mine online (not this site) – it arrived in a plastic bag without packing)
He said my replacement element was faulty.
so I tried another one.
The machine now works perfectly…
