Hoover optima ophs 712b
  • #94895
    Badnessbass
    The drum can only just be turned by hand and is very stiff .last wash I could smell smoke .i suspect bearings but before I strip machine please could someone tell me if I can actually get at the bearings or is the tub sealed ,thank you
    #458669
    It is a sealed tub.
    Badnessbass
    Thanks , does that mean it cannot be repaired then ?
    #458671
    If it was the bearings I would have expected the drum to be very noisy at the end. if it was not then it could possibly an article of clothing has found its way between the 2 drums and if you can get it out it may survive
    Badnessbass
    Thank you both or your help , it had been noisy for some time ,when I say that it needs a lot of effort to move the drum I mean you really have to put a lot of effort on the pulley at the back to get any kind of movement at all ,there doesn’t seem to be any room for washing to get in there there is hardly any space between drum lip and seal
    #458674
    well even though it could be repaired by the time you have bought a drum and had it fitted you could get a new machine with a 12 month guarantee
    Badnessbass
    Thanks , took the door seal off and looked for trapped clothes ,couldn’t see anything.ran it on a spin cycle and noticed it was smoking but the front of the drum only was very hot
    #458676
    its scrap the tubs gone
    Badnessbass
    Thanks Dave
