hoover oven
  • #93307
    tash
    hi hope this is in the right forum.. i needed a main oven selector switch for a hoover double oven HDO909x
    33701193 13440034
    i ordered it directly from hoover they sent me pt 42814656
    unfortunately it’s different to the original and won’t fit contracted them said there’s another switch
    pt 91204784 but this is almost identical to the first and won’t fit either.. original looks completely different and has a connection block to attach.. any help appreciated.. thanks
    #453873
    Re: hoover oven
    Not that sure but the code 33701193 brings up two models, one Forno Inferiore the other Forno Superiore.
    The selector switch for the Superiore is different to either of the ones you have listed and it is a 41003026 as far as I can see.
    This is a picture of it, looks just like the other one though?
    #453874
    tash
    Re: hoover oven
    thanks for that.. that switch looks same as the ones they sent tbh.. yes on the plate it gives 2 models..thanks
    #453875
    Re: hoover oven
    have edited your post and pictures to make it easier
    what’s the number on the switch under your thumb ? 09 was often hoover part numbers
    tash
    Re: hoover oven
    thanks
    #453877
    Re: hoover oven
    Can only see one model number on that plate, the 1344 number is a date code.
    Can’t see any mention of an alternative switch/wiring in the tech bulletins either. 🙁
    #453878
    tash
    Re: hoover oven
    yea it says hdo909x and hdo906x on that plate.. yes i stupidly put my finger over that no but it starts with the one they sent 91204.. probably end up having a hoover engineer
    #453879
    Re: hoover oven
    have you looked at the switches closely?
    do the units have numbers on the terminals that match up ?
    maybe a case of cutting wires to multiplug and putting separate terminal on
    if it was me I would remove old switch and use a multimeter to find out which contacts open and close and do the other switched match. I assume you have both options to try this
    tash
    Re: hoover oven
    yes that’s an option but was hoping for direct replacement.. numbers n tags don’t match unfortunately but sure i can work it out
    #453881
    tash
    Re: hoover oven
    second switch fitted now..cut off connectors
