Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hoover oven door seal failed with 1 year
- This topic has 7 replies, 2 voices, and was last updated 3 years, 8 months ago by
Twoten.
July 23, 2022 at 2:43 pm #101035
Twoten
ParticipantI replace the door seal on a Hoover HOSM6581N single ovenearly December 2021.
I had a call from the owner to say it’s broken.
This is what I found.This is at the bottom in the centre of the door seal. This hasn’t gone at the joint. The rest of the door seal is in the condition you would expect. The rest of the oven appears to be fairly clean.
I suspect this has been caused by a cleaner or other product but I’ve never come across this before. Usually the joints fail or the door seal sags.
Has anyone else seen a door seal go like this in such a short time frame and know what would cause it?
Thanks.July 23, 2022 at 6:52 pm #483102electrofix
ModeratorThis is the unit with an upper and lower element. Think the unit may be made by Samsung
since the oven uses upper and lower elements could the lower one distort and overheat the seal ?
July 23, 2022 at 8:49 pm #483103Twoten
Participantelectrofix wrote:This is the unit with an upper and lower element. Think the unit may be made by Samsung
I hadn’t considered that. Worth another look.
Thanks.July 25, 2022 at 7:41 pm #483104Twoten
DaveThaks Dave, that looks like a good shout.
The element was distorted and touching the front panel of the oven. I’m surprised there were no clips to hold the element i place like most other makes. That’s what you get when you buy cheap!July 27, 2022 at 5:56 pm #483105Twoten
ParticipantReplaced the element today, found the replacement is about 30mm shorter (without taking the distortion into account) bringing the element further away from the front panel reducing.
July 27, 2022 at 10:21 pm #483106electrofix
Moderatorhopefully thats the answer
time will tellDave
January 10, 2023 at 11:51 am #483107Twoten
Participantelectrofix wrote:hopefully thats the answer
time will tell
DaveHaving replaced the base element and door seal 6 months ago, it’s gone yet again.
The door seal is broken in the centre with another slight split to the left. The rubber isn’t hard and brittle like the last time.
I can’t see any reason for this breaking again so wonder if it’s something the user is doing.
Very reluctant to replace it again as I can’t see it lasting more than another 6 months.
January 10, 2023 at 12:35 pm #483108electrofix
Moderatorwell the element was causing some problem last time but cant think how you can damage a seal
all i can suggest is you get the customer to pay for the seal as you cant continue to fund it plus maybe order it direct from hoover so you can complain at them when it fails
