hi all
anyone know if drum has to come out for paddle replacement on this machine.
customer booked call and informed me it does/he found info on ‘net.
well, the customers always right- :rolling:
clive.
Im sure i read somewhere there is a kit which gives you the measurement to drill a hole in the top of the tub undo screws then refit a bung supplied to block hole.someone may be able to verify this.
thanks for info guys, will try access through sump hose as helo75 says,
reminds me of the early AEG 2000 range where they were held on by 3 screws,
removing 3 hoses would give you access.
clive
