HOOVER PE235 WASHING MACHINE HELP
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HOOVER PE235 WASHING MACHINE HELP
  • #19840
    ELBOW2HEAD
    Hi all,
    My washing machine has suddenly stopped working. I put the clothes in and it switches on but it just stays there and does nothing. I disconnected the machine from the wall and switched it back on but it still stayed the same.
    Any advice please?
    Many thanks.
    #184747
    Dave_Conway
    Re: HOOVER PE235 WASHING MACHINE HELP
    Does the door lock while you’re waiting for it to start ?
    It sounds like a door interlock problem to me 🙂
    #184748
    ELBOW2HEAD
    Dave_Conway wrote:Does the door lock while you’re waiting for it to start ?
    It locks perfectly and water comes in but it doesn’t budge at all.
    #184749
    ELBOW2HEAD wrote:It locks perfectly and water comes in but it doesn’t budge at all.
    Doesn’t budge eh? By that you mean the drum won’t rotate I guess? And I suppose if you just set the machine to ‘spin only’ you would hear the drain pump working but again the drum doesn’t turn?
    If the answer is yes, then the motor brushes will need replacing! 😉
    Click the link below if you need an engineer to sort it for you 🙂
    #184750
    ELBOW2HEAD
    I believe so,are the motor brushes easy to replace?
    #184751
    ELBOW2HEAD wrote:I believe so,are the motor brushes easy to replace?
    A relatively simple job yes (and not costly either) :tup:
    #184752
    Dave_Conway
    They’re here if you need them:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=108
    #184753
    ELBOW2HEAD
    Dave_Conway wrote:They’re here if you need them:
    I opened it up and guess what the connector fell off the motor. I replugged and all is good.
    Thanks all.
    I still have more problem with its loud spinning.
    #184754
    ELBOW2HEAD wrote:I still have more problem with its loud spinning.
    Maybe more foreign objects are still rattling about between the inner drum and outer tub? Loud knocking noises on fast spin indicate a broken drum support shaft and/or drum bearing failure? Uneven floor and machine not levelled correctly?
