Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover Performa 1100
- This topic has 4 replies, 3 voices, and was last updated 21 years, 3 months ago by
admin.
December 18, 2004 at 3:57 pm #7159
KeymasterI have got a Hoover Performa 1100 thats about 5 years old and after each cycle has finished, the fabric softener compartment will not empty even after extensive cleaning with a tootbrush.
I wonder if anyone else has experienced a problem of this kind or may know a solution.
Happy Christmas allRob Ashton
December 18, 2004 at 4:21 pm #121712Martin
ParticipantRe: Hoover Performa 1100
Rob,
First thing to do is take the drawer out, clean it thoroughly especially the syphon nozzle and test it under the tap to see it working! :tup:
Then clean the dispenser cavity with a pan brush or similar, concentrating on the holes directly above the fabric conditioner compartment. You may also need to poke say a plastic cable tie into the holes to clear them thoroughly. 🙂
Finally, check the cold water inlet filter at the back to see if that is clear. 😯
If that fails to solve the problem, then the Inlet Solenoid Valve is faulty and needs replacing 😉
January 11, 2005 at 5:16 pm #121713admin
KeymasterRe: Hoover Performa 1100
robertashton wrote:I have got a Hoover Performa 1100 thats about 5 years old and after each cycle has finished, the fabric softener compartment will not empty even after extensive cleaning with a tootbrush.
i bought a brand new one and from the off it did not use the fabric softener so i called the hoover man up and it to him almost a few munuste to remove the top flit a small plastick ajustable switch and tell me it was set wrong at the fatory. it worked fine for a while and now back to fauly again, my mum has a servis machine and it is 15 yrs old and works better! iwill not by hoover again
January 11, 2005 at 5:31 pm #121714Martin
consumer boy wrote:iwill not by hoover again
I take on board your comments consumerboy and thanks for that, but even Hoover machines do not have a dispenser problem these days that doesn’t have a simple cure :tup:
I refer again to my earlier post here, sort that out and you will get it up and running again…easy :lesson:
MartinJanuary 11, 2005 at 7:37 pm #121715kwatt
KeymasterConsumerboy, take a very wise tip, don’t buy a Servis either! 😉
