Re: Hoover Performa 1100 ac110 keeps stopping mid cycle
When it stops between 4 and 5 what happens if you click the timer on a step or two? Does it complete the cycle? Or does it stick again?
If it completes the cycle, when clicked on, I would say it is stopping because the water hasn’t heated up to the correct temperature in time?
No. 4 is a cold fill only cycle anyway so the hot pressure won’t effect it.
Unplug machine if you are going to remove any panels.
