Hoover PPC160
  • #40610
    hotpnt
    Hi, condenser dryer, how the heck do you get to the heater plugs?, took front panel off part way & could see the plugs at back, near motor, does the drum have to come out to change heater???
    #267006
    helo_75
    ppl say not
    i cut and butt them
    drum out? dont go there !!
    #267007
    hotpnt
    Re: Hoover PPC160
    cut & butt inside the rear cover?
    #267008
    helo_75
    yup
    #267009
    helo_75
    dont worry, theyre a bit better than the hotpoints, moisture isnt a problem
    #267010
    hotpnt
    Re: Hoover PPC160
    thanks, wasnt looking forward to it, but should be OK now
    #267011
    timdowning
    Re: Hoover PPC160
    If you push in the ty-wrap end that protrudes near the back cover you can carefully pull the wires through the hole where the black grommet was.
    You can then disconnect old heater and connect new one properly. Then through the grommet hole you can guide the ty-wrap back in place. You can do it with your finger if you have skinny fingers or you can use a wire coat hanger (bent to the correct angle).
    Much tidier than cutting and butting.
