Hoover Saver 1200 (H120m) – HELP!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover Saver 1200 (H120m) – HELP!
  • #11856
    jackster
    I hope that maybe someone could help me with a problem I have got with the above washing machine. I am relatively new to this game, i have recentley completed my training. I have been servicing washing machines succesfully up until now! I have got a problem in that as the washing machine starts to spin, it makes a loud banging noise, the whole tub is basically shaking and banging against various other parts of the machine. I have checked changed the dampers as they were in a bad state but although the noise is now not so bad it is still banging. As I said it is only on the main spin, the pre spin is fine, it is obviously when it is in full flow that it generates the movement. iF I actually grab the tub from the back and push it back and forth it seams very easy to do so, in that their is a lot of play ……………….. can anyone help?
    #146931
    Simon46
    Re: Hoover Saver 1200 (H120m) – HELP!
    Concrete Loose?
    Regards
    S.
    #146932
    Cracked drum support? Poor drain? Dodgey speed control?
    HTH
    Is it on wooden floorboards? These can be a problem if they’re bouncy.
    If the dampers were “in a bad state” then the customer may have been tolerating the condition for some time. Has s/he said as much? Always get as much info from them as you can before you start.
    #146934
    jackster
    Hi all, thanks for the help. The machine is actually my mum,s. This has been happening for a while, she did have an engineer out around 2 months ago but he couldnt fix it. She now tends to just stop the spin when it starts. I decided to have a crack at it for her, thought it would be more good experience for me. Up until now i have had a 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} success rate so a kick in the teeth was inevitable eventually!
    The machine is on vinyl flooring, i have checked the level etc. The main banging and vibrating is at the bottom of the tub, you can hear it knocking against what is probably the front panel.
    #146935
    bazza500
    Simon46 wrote:Concrete Loose?
    Regards
    S.
    Simon46 sounds like he`s hit the nail on the head. Check the concrete block on the front bottom of the drum. The bolts had a tendency to snap.
    #146936
    Might be one of those where the concrete is bolted to the plastic drum front plate and the mountings break. Nice bit of experience for when you’ve got a few hours to spare 🙂 (Worst case scenario-Hoover cover parts only on most machines under 5 y.o. but you have to pay a hefty call out/labour charge). Nah, take your time, make some space in the kitchen and get on with it.
    One last thought- you’ve checked the tacho coil?
    #146937
    jag-12
    Just had similar problem on Hoover auto.Changed dampers but still knocking then noticed black powder traces on inside cabinet.Concrete block seemed solid but retaining bolts nipped up half a turn.Result silent spin!!
