Hoover SE220
  • #21643
    geoffmackay
    Sold this machine as secondhand with a new P50 motor fitted to it. Customer has been doing a 40 deg wash fine but during a 50 deg wash a problem has arisen. Machine fills ok to correct level then drum turns once and timer starts turning (a bit like the Indesit). Machine then empties within 60 seconds of starting and machine goes into full spin ok.
    Checked heater and stat ok, asume its a board fault?
    #191985
    phil59
    hi had this before was relay on board faulty
    cheers phil
    #191986
    geoffmackay
    Re: Hoover SE220
    Going to change it. Thanks Phil.
    #191987
    Tony_EMW
    Re: Hoover SE220
    Sounds like the classic slave timer fault (unlike Indesits where it is NOT the timer). We stock them at £20+vat Tony 0115 9652118
