Hoover SE220 motor speed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover SE220 motor speed
  • #11870
    brianc
    My Hoover SE220 machine is 5 years old and has been no trouble until recently. It was not spinning properly and eventually not even turning over properly. Also there was a crackling noise during running. I had the back off and checked the motor during running when there was obvious arcing at the commutator. I changed the brushes for new and cleaned the commutator. However now, when on the wash part of the cycle, the motor runs at high speed for a few seconds, then reverses at high speed for a few seconds and so on; almost as though it is doing its normal wash cycle but at high speed. Probably because of the high speed, the tub vibrates terribly whenever it is turning.
    Any ideas?
    #146994
    Re: Hoover SE220 motor speed
    Tacho magnet off/loose; tacho coil open circuit; armature down to earth; faulty control board are the possibilities.
    Power off if going in please.
    brianc
    Thanks for your help.
    It was a faulty tacho + the machine now works fine.
    regards,
    brian
