Hoover SE220 wont spin
  • #45790
    spanner51
    I went to this washing machine and when put on spin it tumbles in one direction for 10 secs then it stops and I get no action, the pump continues to run. There is a click from a relay on the module just as the motor stops. If I switch it off then back on again the same thing happens.
    This is one of the machines with the speed control module at the bottom, and a mechanical timer. I was thinking module but I’m not sure. Any help please?
    Graham
    #287079
    Re: Hoover SE220 wont spin
    Relay terminal on PCB probably needs cleaning and resoldering?
    #287080
    loopey
    megger the heater , low insulation can cause this to
    phil
    #287081
    spanner51
    Thanks for the replies. I cleaned and tightened module connections and replaced a sticking pump and it works OK. Happy customer
