Hoover SE264
  • #25500
    jumbo007
    Hi I have a Hoover SE264 and it has a nasty fault that leaves the pump running when the wash has finished. The pump is not running properly just clicks allot.
    #206140
    suedehead1
    Re: Hoover SE264
    are you sure about the make and model number
    #206141
    gegsy
    Re: Hoover SE264
    suedehead1 wrote:are you sure about the make and model number
    Yes 😉
    #206142
    Re: Hoover SE264
    I take it that the water has not drained then?
    jumbo007
    Re: Hoover SE264
    Hi thanks for reply.
    The Model is SE264 (well that is what it says under dial)
    the machine completes the program no water left in but the pump still runs but as if it is not getting 240V as it just clicks like it is getting a rogue feed.
    I have unpluged the heater plus motor to make sure of no earth leak but the pump still gives the odd click.
